Troy-Bilt Pressure Washer
Old 07-24-13, 09:01 AM
Model 020316 with Briggs & Stratton 875 series motor. The pull cord mechanism is stripped and will no longer coil; string pulled all the way out. No tension on the spring. Any ideas on where/how to get a new part? thanks
Old 07-24-13, 09:54 AM
cheese's Avatar
Received 120 Upvotes on 110 Posts
Find your engine model number (probably stamped on the metal shield over the muffler) and then you can look up a parts diagram and order the recoil spring.
Old 07-24-13, 05:04 PM
Received 1 Upvote on 1 Post
In most cases your stuck with having to buy the whole side cover with the recoil included on A Troy-Bilt.
That model number does not work when looking it up. It's missing numbers and decimal points.
