Toro Personal Pace Mower
Hi, I have a Toro Personal Pace mower, the Model # is: 20018 and Serial # is: 220006368. I am missing a screw that I believe is one of the screws which mounts the engine to the housing. I have attached a image to show exactly where it is located. I tried the looking at the assembly diagrams, but can seem to locate the size of the screw anywhere. Can some please advise the size of this screw so that I can replace it as soon as possible ?
If there are 3 mounting screws in the bottom of that engine you don't need a forth,,Most come with 3. Anyways the bolts are a self taping bolt and are 3/8" and the thread is 16 threads per inch and is about 1 1/4" Long. In other words 3/8"x16x 1 1/4" long can also be 1" long whatever works for you.
Sorry I'm back again. Can you advise if this screw attaches from the top of the mower deck or from underneath ?? I can't find where from underneath it would start and from the top it's a bit ackward getting it started. Would appreciate it if you could advise further. Thanks.
They start from the underneath. Like I said earlier, if there are already 3 in the motor a fourth is not needed. If this is a Self propelled unit it may be covered with a belt guard.
