Homelite Trimmer F2020 UT20789
Old 08-18-13, 02:26 PM
Starter cord and pulley ok but not cranking engine. Does this model have a clutch or other type of interface with engine.Would appreciate details of parts needed and procedure for replacement
Old 08-18-13, 08:19 PM
cheese's Avatar
Received 138 Upvotes on 127 Posts
Look for the clutch dogs on the flywheel. They are probably stuck in the out position.
Old 08-31-13, 06:55 PM
Homelite trimmer F2020 UT20769
Thanks for advice. I have stripped down the trimmer which does not have a clutch but only a rotor. The springs in the rotor are broken and so the pawls do not connect to the pull starter wheel. I have tried to source the complete rotor kit no UP03009 without success.Could probably refit torsion springs if I had part no or source,Kind Regars, SeamusHynes
Old 08-31-13, 10:55 PM
cheese's Avatar
Clutch dogs/pawls, same thing. It's a type of clutch. Your local small engine shop may have a junk one in a pile you can get parts from. Ask for the flywheel, or search one on ebay.
