Poulan PT17 Gas Trimmer
Greetings - The throttle trigger and attached throttle cable need to be replaced as well as the two fuel type lines coming from the primer bulb . The fuel lines were damaged as a result of the ethenol that they force us to use during the summer months. The throttle cable was pulled out of the housing by a good intentioned son. I need to know if there are any special positions that this is routed thru so that it has the correct tension so it will operate the carb?Your knowlege is greatly appreciated. I tried to aquire a copy of a service manual but with no luck.
Try this internet address:
Poulan E-Store
and click on view partlist.
the next window that comes up click on the illustrated parts list folder in the right hand window.
then click on one of the three icons
Poulan E-Store
