Kohler dual cam timing
Old 09-14-13, 01:39 PM
R
Still haven`t found from anyone on how to time a sv600;spec #sv600-0018; ser nu. 3733823283; still can`t get a responce , the manuel says with piston top center that you put intake cam mark on 4pm and the exhaust cam on 8pm this will not aliegn when turning engine over, any help would really be appreciated, thanks
Old 09-14-13, 03:40 PM
Received 27 Votes on 26 Posts
What are you referring to when you say they don't align when cranking the engine over?
Old 09-14-13, 04:19 PM
31YTech's Avatar
Hello Ronmac1117,
As long as you align all the marks as below you shouldn't have any issue..... Now..... Rotating the crank one revolution from TDC compression will put you on exhaust stroke, Rotating another revolution will put you back at TDC compression and re-align the timing marks.....
Good Luck
Old 09-14-13, 08:42 PM
R
thanks 31Vtech, will give this a shot as will also have to replace the new governor, old one bursted inside motor is reason I had to break motor apart.
Old 09-21-13, 07:04 AM
R
Sir, Have done all the above and it still want crank, let me go over one more time, If I am sitting in front of spark plug hole and align gears with the timing notches on crank with the crank keyway straight toward me and piston top center, then you say it should crank, but it has a bad kick back and only pops. something I am doing is just not right, told ya`ll I was an old gizzer , hard to figure this out, lol
Old 09-21-13, 10:12 AM
cheese's Avatar
Received 87 Votes on 81 Posts
Your flywheel key may be sheared.
Old 09-24-13, 10:21 AM
R
new key, took it to repair shop, thanks
