No Spark While Cranking
Old 10-04-13, 10:14 PM
K
8hp Briggs, with magneto ignition and magnetron coil (no contact points). While cranking, no spark. Release the starter, and a spark per revolution while the crankshaft spins down. No play in crankshaft bearings. And of course, a magneto ignition does not require battery voltage to generate a spark. This also happens with the kill wire disconnected.
Old 10-04-13, 11:02 PM
cheese's Avatar
Received 120 Upvotes on 110 Posts
Generally I would say you have a bad switch, but if it does this with the kill wire unplugged from the coil, then you have a bad coil.
