Honda eb5000x Generator
Old 10-17-13, 11:59 AM
B
Hello there, I have a honda generator eb5000x SN:ea7-3015281 that will not start. I have already cleaned the carb, there is spark being generated, but the inside of the engine is not damp from fuel. Upon further investigation, I have found that the fuel shutoff solenoid does not get power. Any suggestions?
Old 10-17-13, 05:22 PM
cheese's Avatar
Received 122 Upvotes on 112 Posts
I would check the fuse and the keyswitch for power.
Old 10-18-13, 04:37 PM
B
It has a recoil starter, and I did not see any fuses when I took apart the control panel. The shutoff switch works as it says in the manual.
Old 10-18-13, 09:56 PM
cheese's Avatar
Okay, how does the fuel shutoff solenoid get power to allow it to start?
Old 10-18-13, 10:27 PM
Received 3,485 Upvotes on 3,128 Posts
In looking at the schematic for that unit there is no fuel shutoff valve shown. I do see it in the parts list though.
I have the EM5000SX series units that have a 12v DC output that also runs the electronics and the fuel solenoid. I have one that is setup for electric start and the other I just use the pull start.
Old 10-20-13, 04:46 PM
B
The continuity of the switch contacts.
I suspect that maybe the DC generation bit in the generator may be issues.
Old 10-24-13, 10:49 AM
B
The resistance over the solenoid reads 7.5 ohms? This is good right?
Old 12-03-13, 11:13 AM
B
Ok so now it runs, but not smoothly. It starts fine, but the engine speed cycles over and over again.
Old 12-03-13, 11:40 AM
B
Ok, I tightened the air screw on the carb, the engine speed is much more steady.
However, the engine skips occasionally. Could his be due to bad gas?
