key wont turn on my craftsman snowblower
Old 12-16-13, 05:58 PM
Used the snow blower three times yesterday, today went to start it and the key wont turn. I used a lock de-icer and of course that would of been to easy and it didn't work. Is it something easy or do I need to call for help
Old 12-17-13, 03:45 AM
Norm201's Avatar
Received 61 Votes on 57 Posts
Just as a test, short out the contacts. If it starts then replace the key mechanism.
Old 12-17-13, 04:03 AM
Received 342 Votes on 320 Posts
Most key switches create a short in the off position so that they ground the primary coil wire.
A blow dryer may be needed for a little spot heat. After it is unthawed.... then you can lubricate.
Old 12-17-13, 07:42 AM
WD 40 will help displace the water in the switch.
