Snowblower: SeaFoam?
Old 12-19-13, 09:03 AM
B
I have an older 5 HP, 4cycle Ariens snow-blower. I put it away last year and did not put stabilizer in the gas. The machine fired up and ran for about 20 minutes or so. I put it away and have since put in fresh gas.
However, the machine is running rough, even after putting in a new plug. Plus, it will only run while on full choke.
Was thinking I should try Sea Foam to get it running smoother.
Anybody try this stuff. Comments?
Anybody ever put in with oil in crank?
Thanks
Old 12-19-13, 09:11 AM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Supposed to be good stuff, but kinda pricey. It can't work miracles of course. You may still need to do a carb re-build, but it's worth a shot I'd think.
Never put it in the oil, gas tank only. Didn't help as I had an idle control issue.
Old 12-19-13, 10:11 AM
G
Received 30 Upvotes on 29 Posts
SeaFoam is wonderful stuff if the problem is varnish, it can't do much for dirt and other trash but is amazing on varnish, drain the old gas then mix 1-2 ounces in a pint of gas and let it run for 10 minutes, let it set for 30 minutes, then run it until it quits, you will probably hear the engine change tempo as it runs. Have a good one. Geo
Old 12-19-13, 10:18 AM
A
Received 73 Upvotes on 66 Posts
I have had good results a in a few similar situations. As mentioned, it's not going to perform miracles, but no way to say for sure without trying it, so I definitely would.
Old 12-20-13, 05:35 AM
I use it a lot and recommend it over stabil to my customers. It is not a miracle solution however it works ok for me.
Old 12-20-13, 09:08 AM
W
Received 1 Upvote on 1 Post
I bought a snow thrower 2 years ago. From the beginning I've added 1 OZ. SeaFoam per gallon when filling up. Store it wet and it's runs great every season. I'm currently using the gas I purchased last Feb. and its running strong. I use SeaFoam in all my OPE gas.
Old 12-20-13, 09:14 AM
O
Received 11 Upvotes on 10 Posts
1 oz per gallon would do a fine job of keeping the problem you have from originating, but now that you have it, I would go with Geo's concentration of 2 oz per pint in an attempt to fix it. If it doesn't you will need to do a manual carb cleaning.
