Tecumseh TVM220-157287L flywheel magnets broken...can't find any ... any ideas?
Old 12-23-13, 01:29 AM
B
I have a Fisher sander/spreader powered by a 10hp tecumseh tvm220-15728L verticle shaft motor and while removing the flywheel I dropped on concrete & broke 2 of the magnets. Anybody have any idea where I can find some magnets for my flywheel 611094? Obviously I would like to just replace the magnets being that Tecumseh out of business now & they want between $185-$238 for flywheel & magnets... I took the flywheel off to clean it because it was all rusty and binding up its now clean but I do not have all the magnets.... Just want to save money & reuse the perfectly good fly wheel I have ... Thanks Guys
look forward to hearing some resolutions.... (E.G.) cross reference for different flywheels that I could get same type of magnets from...etc...
Old 12-23-13, 06:52 AM
Received 1 Upvote on 1 Post
The Mags
Check lawnmower shops especially the ones that have been around awhile. Some of them salvage old motors for parts. You might get lucky. I have had good luck on several occasions. Even found a tecumseh flywheel.
Sid
Old 12-23-13, 08:29 AM
B
Thank you ...have tried & I am so frustrated.
Old 12-23-13, 10:56 AM
cheese's Avatar
Received 138 Upvotes on 127 Posts
Do you have to broken pieces? If so, put them back on using JBweld and it will be fine. If not, check ebay for a used flywheel. I think I have one or two of them in the shop.
Old 12-23-13, 04:11 PM
B
Don't have all the pieces....I have this dog that likes to eat things..... 90lb pitbull....picked one up & by the time I got it from him it was in 100pcs threw it out figuring that I could just replace.... man, was I wrong... never again I own nothing but briggs & stratton with all the other equip ( I didn't even know that tecumseh went out of business).... only thing I have is an ariens snow blower thats junk but no magnets.... tried ebay most do not have ring gear & magnets on bottom... & if they do...over $130 used w/o ring gear (going to be very difficult to remove ring gear due to rust on bolts.. they are counter sunk)....... my flywheel is in perfect shape now that I wire brushed it. I mite have to just break down & buy one.
Thanks for the advise ....I was hoping someone knew where to get just the magnets
Old 12-23-13, 04:44 PM
B
I don't know if this helps but the casting #'s are 13-0-48G & 307G or C
Old 12-23-13, 04:49 PM
B
Correction just put my other eyes on... 13-0-48C & 307C
