Honda HS520A snowblower - Choke rod and knob disconnected
Received 0 Votes
I bought Honda HS520A snowblower last month.
It had been working fine until today when I tried to start it again.
When I pulled the choke out, the know along with the rod came off.
(a picture attached)
How do I put it back?
![Name: IMG_2111[1].jpg
Size: 12.5 KB](https://www.doityourself.com/forum/attachments/outdoor-gasoline-electric-powered-equipment-small-engines/24386d1389138113-honda-hs520a-snowblower-choke-rod-knob-disconnected-img_2111-1-.jpg)
It looks like there is a little plastic sleeve that holds it in place. You appear to be missing it.
In the parts breakout, part 1, it's called a cord grommet, which looks incorrect.
Parts and Diagrams for Honda HS520 ASA SNOW BLOWER, USA
Received 0 Votes
PJmax, thank you for replying to my question promptly.
I will look for the plastic piece which I must have dropped.
I looked at the parts' diagram, but I could not figure out which hole the bent end of the choke rod goes into.
Since it has a 'S' curve, it must goes through a hole big enough, but small enough to retain it.
Can you help me find the hole?
Thank you.
Thank you.
Received 0 Votes
I had a warranty service performed on this....
I was told that I needed to take the cover off to do anything to begin with. I tried to take the cover off and I could not, so I took it to a Honda-authorized repair shop.
Thank you for your help.
