Washers keep falling off
My good friend has a Sears snowblower. I do believe that it is a 536.xxxx model. After every storm this winter (3 so far) he has called me because he only has 1 speed and no reverse. I remove the bottom plate and fine the 2 washers in that plate. I put them back in place and the next storm same thing. These are the washers I am talking about.
washers go on #28 bearing
So when you say the washers for the bearing are falling out does that also mean the bolts are coming loose and falling out? If so I would re-install them adding lock washers and/or using a thread locking compound like LocTite. Use the blue color which is removable.
The bearing nubs sits in the slots in the engagement arm #19 (probably actually called something else)? Those washers would only come out if the travel of the arm was too great. As long as the the arm travel was within range the washers would stay put. That's setup is something like the old cat dozer dry clutch, actually.
There is likely something on that drive shaft either worn or a pin missing that lets the friction drive move too far. That lets the arm move the bearing too far and the nubs come out of their slots and the washers fall off.
OK Let me re-phrase the problem. The problem is that the bearing keeps coming out of the forks.The forks are not bent.The shaft is lubed and slides easily by hand. Everything works fine by hand and works by lever. I am at a loss here. Thanks guys.
When you put the bearing drive nubs back into place how are you doing it? Are you dis mantling the bolts from the friction drive or are you simply forcing the bearing back into place in the fork.
I imagine the problem is in the bearing or its interface with the friction drive. The bearing could be a little rough or a part of the interface strikes the outer casing on the bearing. Either would let the friction drive turn the bearing casing and spin it out of the forks. The washers are likely part of the design to prevent the casing from turning as opposed to just being spacers.
You may have to pull the bearing to see what shape it's in and what's striking what.
