Cummins 3000 generator no voltage output
Old 01-12-14, 12:23 PM
T
Hello, I have a Cummins 3000 Generator with a JF 200 Jiangdong 6.5 hp motor.
the motor starts right up, however, I get no AC output. I had bought a new AVR thinking that was the issue. While replacing the AVR I noticed a broken connector on a wire. I fixed that connection and even with the old AVR, I had power output. Put Generator in back of my pick up and drove home, and got home, an no voltage output, even with new AVR. I re-re-checked my wire connections etc., and see no obvious issues. Brushes look kinda worn down, but it worked before the drive home,
Any ideas on what I can look for here? I have not tested AC while running yet, I did before I got it working, but not since, so I don't have result for the different points. I will do that here soon though. In the mean time, any thoughts????? Thank you in advance for any ideas.
Tom
Old 01-12-14, 12:26 PM
T
p.s.
p.s. I did take the control panel off and check the wire connections, circuit breaker and kill switch, etc. , all looked ok. tested breaker ok
Old 01-14-14, 09:03 AM
Justin Smith's Avatar
Received 1 Vote on 1 Post
Try flashing it. You can find how-to videos on Youtube.
