Gas powered pressure washer will only start with trigger handle pulled.
Received 0 Votes
I have a nearly new gas pressure washer with a pull rope that is impossible to pull unless the wand trigger handle is pulled. In other words without water flowing out of the wand the engine will NOT pull. If I clamp the trigger open and then pull the rope it starts and runs fine.
What can be causing this?
