Did I get sold a lemon snowblower?
Old 02-17-14, 05:30 PM
C
It's an ~10 year old craftsman 24" two stage with a tecumseh motor. Checked it out and everything seemed to work fine when I was there, but since getting it home, the following has happened:
* Was trying to cut into some fairly deep snow and the motor bogged out and stalled, wouldn't start back up
* in the process of trying to pull the rope, it snapped
* let it sit a couple days, after which it starts back up (electric start), but was backfiring and eventually stalled
* Tried turning the choke open, loosening the gas cap, etc....no luck
* Noticed just today that it stalled out as soon as I opened the choke
He claims he got it from a guy that accidentally filled it with water, but he cleaned the carb up and it was fine
I also noticed that he started it up without the choke while I was there. What could be the issue on this?
Old 02-17-14, 06:00 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums. Caveat emptor.. Some of the things I would expect from an old machine, like the rope breaking. Water in gas tank..not the brightest bulb in the pack, but it can be fixed. Backfiring can be from a worn or semi-sheared key on the crankshaft.
Old 02-17-14, 09:09 PM
Received 1 Upvote on 1 Post
Just had to chuckle. 10 years old, more then one owner would have told me old fuel, rotted pull cord, dried out fuel lines, no nonethanol fuel ever used, carburetor needing to be rebuilt.
Old 02-18-14, 08:31 AM
O
Received 11 Upvotes on 10 Posts
My guess, since it died under heavy load, is that the flywheel key, that controls the spark timing, has been damaged.
