Case 1830 Uniloader: starter/solenoid
Received 0 Votes
Considering replacing myself. Bad idea? Is this a 10-20 step operation, or am I in way over my head?
Received 0 Votes
Can you help?
This is not helpful for you, but is there any way that you can measure the length of your oil dipstick on your 1830 uniloader? I have lost mine, and I need to know the length to replace it.
Welcome to the forums c1319wing!
Have you checked with the Case dealer to see if they have a replacement dip stick? I know on my old ford tractor those are items I can order.
Received 0 Votes
They sell two different lengths for $80. If they order the wrong one, it's a $25 restock fee. If I have the correct length, i don't have to even order special one. I can just cut one to correct length.
Just drain the oil & replace it with the correct amount. If you have a filter you will need to run the engine to fill the filter. let it sit for an hour. than take the measurement & make your own dipstick... Hope this helps,,, Roger
