Portable generator
Old 02-24-14, 01:33 AM
W
Portable generator
I have a 5500 wheelhouse generator which had a quick connect gas line coming from tank to carb.The quick connect line was leaking fuel so i did away with the quick connect & ran a straight fuel line from tank to carb. should this be ok with the straight line.Thanks for your help
Old 02-24-14, 03:30 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Tank, as in gasoline, or propane? If propane, make sure the hose id reinforced, but you should have no problem doing away with the disconnect, except convenience.
