Mystory wire on B & S Quantum 6.5 HP Engine
Old 03-05-14, 03:46 PM
Question Mystory wire on B & S Quantum 6.5 HP Engine
I have a Trot Build pressure washer
Engine model # 020207-00
Serial # 1009533560
On the side of the engine where the carb is located there is a black wire, from what was able to find out it might be item 268 on the engine parts list. Does anyone have any ideas about and where this wire is should to go??
Old 03-05-14, 04:02 PM
Rough Rooster's Avatar
Received 16 Upvotes on 12 Posts
Black wires close to carb on Briggs engines are usually the magneto kill wire.
Most times they are fastened under an insulated clip on throttle slide and when throttle is closed it shorts this wire to engine ground stopping engine.
RR
Old 03-05-14, 04:25 PM
thanks for the information
