Tecumsa 6HP Lawn Mower engine
Received 0 Votes
Before I begin to search and destroy, my Tecumsa will start but only continue to run with my thumb on the priming bulb.
If I let out the bulb the engine will stop.
Replace the priming bulb. Most likely has a crack in it that is allowing air to get through it to where it doesn't belong.
Might try placing a piece of tape over the primer bulb and see if it will then run.
RR
RR
