Husqvarna Chainsaw chain won't spin fast
Old 04-01-14, 07:53 AM
P
Hello, This is my first post and I didn't see any other post that was quite like my situation.
I have a 1 year old Huqvarna chainsaw. I winterized it and went to use it yesterday. It started first pull but the chain spins really really slowly. I also noticed the hand brake didnt slide back and forth like it should. My dad and I took it apart and back together and seems the hand brake feels and sounds right but the chain barely moves, but it does move. With the brake engage it doesn't move at all.
Any ideas?
Thanks.
Old 04-01-14, 09:35 AM
cheese's Avatar
Received 54 Votes on 49 Posts
Hello and welcome!
Is the chain rusty? Is it too tight? Can you spin the chain by hand easily?
Old 04-01-14, 09:39 AM
P
Received 873 Votes on 803 Posts
Try removing the bar. Hold it vertically with the sprocket tip up. Place the chain over it and in the grooves of the bar. Pull the around the bar. Does it flow smoothly or bind up? If the chain won't go into the groove or if it binds then I would try a new chain. If you bound the saw and twisted it's easy to put a slight bend in the chain that prevents it from riding properly on the bar.
Old 04-01-14, 12:01 PM
P
I can move the chain around the bar by hand, it lays in the groves easily, no rust on it.
Old 04-01-14, 12:18 PM
R
Received 44 Votes on 35 Posts
Something isn't right with the chain brake, the band may be stuck. I haven't got mine out to look at it but I believe the problem is in there and the tension should be adjustable once you free it up.
Old 04-01-14, 04:40 PM
cheese's Avatar
I tend to agree with Ron53, or else the teeth on the sprocket are worn through and not pulling the chain anymore.
Old 04-01-14, 04:53 PM
Received 19 Votes on 18 Posts
Does the engine rev normally off the throttle (chain on the saw or off) or does it seem to bog down like something is holding it back?
Old 04-02-14, 06:02 AM
W
Received 32 Votes on 29 Posts
Chain Saw
Check around the clutch/sprocket area for trash. Wood chips or vines will bind up the sprocket and give the symptoms you describe. Also, does the bar have a sprocket in the outer end of the bar? If so, this can also be a problem area.
Old 04-02-14, 09:20 AM
P
I took it apart again, and looking online it seems I originally took the cover off with brake set because now i can't align the grooves of the brake into the silver wheel-thingy (below in the pic) on the saw cover, which I think was the issue all along. Name:  brake.jpg
Old 04-02-14, 12:29 PM
A
Received 4 Votes on 4 Posts
Husky
Now that the brake is set there is two ways to release it. One hold the saw on it's side hold the cover on push the brake handle forward until the cover drops onto the handle than press down hard and pull the brake handle back to release the brake. Or you could make a tool:
Tripped:
Released
Old 04-02-14, 03:27 PM
P
I was able to put the cover on and move the brake back. I attached the cover and the brake moves back and forth like it did last year. But now I started it up and the chain still did not move and the engine cuts off when I pull the trigger.
Old 04-02-14, 03:57 PM
A
With the saw off & the brake released can you move the chain by hand? Use a pair of gloves.
