TSC 8 HP Briggs and Stratton Tiller - No spark
Old 04-18-14, 01:41 PM
Hi. I have a TSC / Husky rototiller with a 8 HP Briggs and Stratton (19402) engine. Ran great last fall. Tried to start this spring, to no avail. Troubleshoot to no spark. Have pulled the flywheel. Condenser and points housing looks clean and gaps appropriate. Am considering replacing coil with a magnetron coil. Can I just buy a new magentron coil or do i need to buy the conversion kit that Briggs sells that attaches to the old coils? Any help is greatly appreciated. Thanks.
Old 04-18-14, 04:54 PM
Received 35 Upvotes on 34 Posts
I would just put a new module in it and be done. Since you have the points exposed, pull those and the condenser. Then all you'll have for an ignition will be the module/coil, spark plug and kill switch.
Old 04-18-14, 06:21 PM
cheese's Avatar
Received 146 Upvotes on 135 Posts
Since you don't know if your current coil is the problem or not, I'd just buy the whole new coil with the electronics already inside. This way you will have eliminated all old parts in one easy to replace item.
