An HMSK80
Old 04-22-14, 06:57 AM
Received 1 Upvote on 1 Post
An HMSK80
Hi All
I bought a '95 Murray snowblower that has low hrs but was stored outside for several years. I was checking the engine [ Tech], and I rotated it by hand, and I would hear a click near TDC. I was afraid to run it, so I opened it up. The engine could not have more than 10 to 20 hrs on it, every thing was clean and tight. What I did see was what looks like a unloader on the exh valve cam lobe, that I think is what making the clicking noise. Please tell me that that unloader is is noisy. Thanks.
Sid
Old 04-24-14, 07:26 AM
Maybe I should have said a snowblower engine. I was hoping that someone might of had the same experience that I had with this engine.
Sid
Old 04-24-14, 09:05 AM
P
Received 2,008 Upvotes on 1,800 Posts
I assume what you're seeing is the compression release to make it easier to start. I've never really called them noisy though. Something you had to be listening for.
Old 04-24-14, 03:51 PM
The Hmsh80
Yeah, I heard the clicks when I rotated the engine by hand, and I just wasn't sure that it was not something bad. I got a couple of assurances that it was more or less normal, and I will see what happens, as soon as I get new oil seals. Thanks.
Sid
Old 05-06-14, 06:29 AM
The HMS80
Well I finally closed it up, and it seems to be running fine. The test will be the first snow next season. Thanks.
Sid
