click when turning key, replaced solenoid, intermittent problem, craftsman 42"
Old 04-29-14, 06:45 AM
C
hi
i have a craftsman 42" cut mower, the mower quit starting and would only click at solenoid, i replaced the solenoid and now the mower turns now and then and the other time i get the same click, any suggestions.
thanks
Old 04-29-14, 07:34 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I thought I responded, but it didn't take. Have you checked the charge rate on the battery? Not just the voltage, but under load? Your battery may be too weak.
Old 04-29-14, 07:49 AM
C
have not checked charge rate, but had battery checked under load at reputable battery shop, checked good, also i jumped the solenoid once and cranked perfect
Old 04-29-14, 08:16 AM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
I'd suspect dirty cables or grounds.
Old 04-29-14, 02:33 PM
cheese's Avatar
Received 146 Upvotes on 135 Posts
I agree with Gunguy45... likely loose cables at the battery.
