toro mower blade problems
fauxgirl's Avatar
04-30-14, 02:23 PM   #1
I have a toro 22 inch recycler mower model # 20067 and am trying to replace the blade for the first time. the parts manual says the blade # is 108-9764-03 which is what I have. However, the blade does not seem to fit-when it turns it hits what I think is called the baffle. I'm inserting a picture of the problem. I do not understand what I am doing wrong. This is the third blade I have bought (ok I had the wrong serial number the first 2 times) and I am ready to pull my hair out. Can someone please help?Name:  IMG_00000308.jpg
Size:  34.5 KBName:  IMG_00000310.jpg
Vermont's Avatar
VT
04-30-14, 03:22 PM   #2
Could it be that the baffle is a mite de-formed. or pulling away from the outer shell a little bit ?
I have a 22" Snapper configured similar to that. I'll go and look at it tomorrow, and see if there's limited clearance in that area.
cheese's Avatar
GA
04-30-14, 08:26 PM   #3
Sure looks like that baffle is bent.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
fauxgirl's Avatar
05-01-14, 05:31 AM   #4
I checked the baffle for tightness and it looks like the pic from the parts catalog so I don't think it's bent. I appreciate you guys looking at it. I'm stumped
Vermont's Avatar
VT
05-01-14, 07:02 AM   #5
It would appear that the "baffle" started out being flush to the mower housing along that short area where the left rear wheel is mounted. Maybe it can be bent back, or you can get someone to do a little welding to firm it up.
A brand new blade (especially a Gator Blade like I see in your photo) is going to fit much tighter than an old worn one.
I wonder if the new blade ever rotated counter-clockwise and got hooked on the baffle? Maybe a momentary backfire ?
Gunguy45's Avatar
Super Moderator
AZ
05-01-14, 07:13 AM   #6
It's definitely bent Fauxgirl. Look at your drawing and the pics again. The short mounting tabs at the ends of the baffle are supposed to be parallel to the front of the mower deck. Tilt it the other way and look at the other side. Since it only hits one side (as far as we know) that side is bent into the blade path.
Take off the whole baffle and it can probably be flattened and bent back to clearance. I'll bet the front part (where the 3 in the diagram is pointing) is pushed far forward of where it should be. Like someone hit a low stump or similar and then jerked the mower backwards to get it off, bending the front part and the side at the same time.
Vic
"I sometimes wonder how some people ever made it to adulthood..."
cheese's Avatar
GA
05-01-14, 09:43 AM   #7
Get a hammer and knock it out of the way.
God bless!
daswede's Avatar
MA
05-02-14, 05:54 AM   #8
I think your blade is on upside down
fauxgirl's Avatar
05-02-14, 05:57 AM   #9
Thanks guys. I think you may be right. If nothing else I'll hammer it out of the way. I don't really see what it is there for anyway. I"ll let you know how it works out.
cheese's Avatar
GA
05-02-14, 09:47 AM   #10
The blade is on properly.
God bless!
fauxgirl's Avatar
05-02-14, 09:48 AM   #11
problem solved
Thanks to all you smart guys the problem is solved I took the baffle off and as you can see it was bent. I pounded it back and wah lah it works. Who knew all it took was a hammer? Name:  baffle 2.jpg
Size:  24.1 KB Thanks so much for your help!
Vermont's Avatar
VT
05-02-14, 12:51 PM   #12
Posted By: fauxgirl ". . . I don't really see what it is there for anyway. . ."
THe baffles are there, (usually front and rear) to keep the bulk of the grass clippings from getting out of the circular path of the blade, where they can be pulverized and discharged.
Without the baffle(s), the wet grass will just tend to accumulate inside the housing corners and clump up as a hardened mass.
fauxgirl's Avatar
05-02-14, 02:14 PM   #13
thanks Vermont, I was wondering why it was there.
cheese's Avatar
GA
05-02-14, 06:10 PM   #14
It also helps create a vacuum to stand the grass up to cut it. Like a fan shroud.
God bless!
daswede's Avatar
MA
05-03-14, 01:17 PM   #15
Cheese is correct I stand corrected
