Weed Trimmer Fuel Line Help Needed
Old 05-04-14, 07:00 PM
Hello all,
I'm interested in getting some opinions on a concern I have. I fix 2 cycle lawn equipment as a hobby and I never seem to have the correct size fuel lines. I have found a very good supplier for 3/16 x 3/32 fuel line, (actual size is 13/64 x 3/32) and it fits many machines but there are some that it doesn't fit. It's mainly some of the inexpensive machines, where the fuel lines run through holes in the fuel tank, that the fuel line won't fit. I could make the fuel line fit these machines and make my life easier in the process, if I slightly enlarged the holes in the plastic fuel tanks. Does anyone see any problems doing this. Thanks for any and all comments. ross
Old 05-04-14, 11:10 PM
cheese's Avatar
Received 146 Upvotes on 135 Posts
If you keep 3 different sizes in stock, you will have the correct size for nearly everything. Is that too many sizes to stock?
Old 05-05-14, 07:11 AM
Cheese, thanks for your response. What are the 3 sizes your referring to and what do you think about my idea?
ross
Old 05-05-14, 09:16 AM
cheese's Avatar
3/16" OD, 9/64 OD, and .204 OD. These will cover nearly everything that doesn't take pre-molded lines.
I don't like the idea of changing it to your own design. If someone later needs to change them again and uses their model number to order lines, they will be getting the wrong line and may have a leak if you altered it. If that leak causes that person an issue, guess who they might be blaming the problem on?
