Kawasaki FE250 runs rough
Received 0 Votes
I own a Ryan LawnAire 28 with an 8hp Kawasaki FE250 engine. The engine starts fine but seems to stumble and, in general, run rough.
The engine has much less than 100 hours on it despite being a pre-2000 vintage. The unit was first used in Cleveland but I'm using it at 5,000 feet in Colorado. Before digging into this I was hoping to get some insight from some of the online experts who may have some ideas. The aircleaner, while not new, is not terribly dirty and the choke seems to work as designed.
Any help or ideas would be greatly appreciated.
Received 0 Votes
Thanks Cheese,
I actually haven't touched it. I did check the air cleaner but did that as a matter of spring start up, etc. I can easily swap out the plug and see if that helps but, like you, I feel it's a fuel issue.
The manual indicates that only authorized Kawasaki repair people should mess with the carburetor but it's just a single barrel carburetor. I was hoping someone has some experience with the carburetor on this engine that may have some ideas. Thanks.
