Lawn mower choke problem and stalling
Old 05-08-14, 04:17 PM
B
Hi everyone,
My Honda lawn mower (hrx217hza) is having problems with auto-choke and starting this year. It take 5-6 attempts with the electric starter( fully charged)and 8-12 pulls with manual for a cold start. Even if it had been running for 30min. it would still take a few attempts to start. Also, the engine is always stuck at choke position even after I finish mowing the lawn( I can see the little lever going front-back-front-back). In normal operation, the lever is supposed to be at the front. I had the mower for 2 years now and it worked fine before. The only difference is that I forgot to empty the fuel tank so there was half a tank of fuel left from last season. The mower starts then stalls in a few seconds. So I drained the bad fuel and added fresh fuel. It still had problems, but it does not stall as often. The oil was also recently changed too . Another problem is that the mower stalls every time I move the throttle to the "Slow" position. It often stalls when I engage the blade too.
Old 05-08-14, 04:26 PM
Received 1,267 Upvotes on 1,207 Posts
Not my area of expertise but you may have gummed up a fuel line or something burning the old gas causing the engine to feel like it's never warmed up and running properly.
Old 05-08-14, 08:35 PM
cheese's Avatar
Received 146 Upvotes on 135 Posts
Sounds like you have carburetor problems and the choke actuator may need cleaning as well, it is supposed to slowly come off choke when you pull the bar on the handlebar down.
Old 11-23-14, 05:17 AM
D
carburetor
Most of the time when a lawn mower or any small engine won't start the cause is, a problem with the gas or the carburetor.
