B&S 3.5hp problems
Old 05-13-14, 11:59 AM
B&S 3.5hp problems
I have a commercial sprayer with a B&S engine; 82232 4007 01 92120703.
I was using it tonight, when it died (like running out of fuel type dying).
I topped up the fuel, and it won't start.
It seems to be burning a lot of oil; spark is sparking; topped up oil, and still nothing...
Any suggestions as to next step?!
Old 05-13-14, 12:07 PM
B
3.5 hp engine
Next thing to see is if the piston is moving. Take out spark plug and turn the engine with a screwdriver in the plug hole and see it engine is turning.
Old 05-14-14, 02:13 AM
The Piston is moving alright...
Old 05-14-14, 07:47 AM
B
If you have good spark, I would put a sqirt of gas or carb cleaner in plug hole and see if it will run that out, if that works you have a fuel issue. Look at fuel filter, loosen the gas cap, or it could just need a good carb cleaning. It could be jet on carb is plugged up.
