Pressure Washer Pump Troubleshooting
Old 05-19-14, 08:49 AM
T
After 20 minutes of using my BE pressure washer yesterday, water started spraying from the pump at the spots indicated in the first photo.
Taking the part off I saw what is shown in the next 2 photos.
The inset (chromed?) part in photo 2 is sitting loose.
The inst brass piece is loose in the screw-in piece as shown. It is flat on one side with a raised center on the other. I don't know which way it is supposed to go. Tried both ways and the water leak didn't stop.
By now it's obvious I know little about gas pressure washers, although this unit has worked well for me for a couple of years.
Any info. on what caused this problem and how to solve it would be greatly appreciated. I live in the boonies and the only local shop can't look at it for 2 weeks. Thanks.
Old 05-23-14, 08:08 AM
T
Follow-up
I was able to stop the water from spraying where indicated in the photo, after figuring out which way to re-assemble the parts, but the pump no longer builds any pressure.
The part #20 "Rod" is threaded at the bottom, but it doesn't have any nut or threaded hole to screw in to??? I don't understand this.
The parts diagram for this pressure washer pump is located here:
http://www.ppe-pressure-washer-parts...0Breakdown.pdf
Without knowing what caused the leak, should I be looking at replacing the whole pump, or replacing the "Reg. Valve Kit + Seat (#13 in the parts list)?
