John deere gas weed eater not spinning
Old 05-19-14, 07:16 PM
D
Received 3 Upvotes on 3 Posts
I've got a john deere weed eater. It's the 2-stroke 50:1 gas oil model. The engine runs fine, but periodically the weed eater part won't spin. I attached the hedge trimmer and the same thing happened. If I jiggle the end and tilt the end up then it'll sometimes start spinning. Is What do I need to get this working again? I looked in the shaft and it looks like the shaft with the square in it is spinning properly.
Old 05-19-14, 09:29 PM
cheese's Avatar
Received 138 Upvotes on 127 Posts
Sounds like the motor might need to be pushed down onto the shaft a bit more and the clamp bolts tightened. John deere put their name on a whole bunch of different trimmers, so saying "it's the 2-stroke 50:1 gas oil model" doesn't tell us what you have. The advice I gave would apply to pretty much all of them though, but the specifics would be different according to model.
Old 05-20-14, 05:56 AM
D
It's a BC1600. How to I push that spinning bolt forward? Is there a screw or clip or something like that?
