Weird Craftsman Lawn Tractor electrical anomally
Old 05-27-14, 08:43 AM
This is a weird one...
I own a Craftsman YT4000 (917.288561) lawn tractor. After doing the annual maintenance (new plugs, new oil, new filters) I decided to also vacuum built up lawn clippings out of the engine compartment.
After I did that, it would not crank. It appeared dead as a doornail. After monkeying with it for 10 minutes I finally discovered it would crank if I turned the headlight switch on. Weird.
Right now, the mower operates normally with the headlights on, EXCEPT the lights don't actually turn on anymore. Weird.
After I start the mower with the headlights on, if I flip the switch to the off position the engine still runs, but the pressure seat switch appears to be disabled at that point. I can get off the seat and the engine will still run. Weird.
So my conclusion so far is that I shorted something out when I vacuumed the engine compartment. And somehow the headlight circuit is jumping it so everything operates normally.
Any ideas where the short could be? Any insight would be appreciated.
Old 05-27-14, 11:10 PM
cheese's Avatar
Received 112 Upvotes on 102 Posts
Lol... sounds like you don't need a mechanic, you need a priest.
I'd look for ground wires that might have gotten knocked loose. Bad grounds can do weird things. I can't fathom how turning the lights on would have any play at all in any operation of the mower though, bad ground or not.
