Briggs 6.5 HP Low RPMs
Old 05-27-14, 06:08 PM
indyhoov's Avatar
Question Briggs 6.5 HP Low RPMs
I have a Craftsman tiller with a 6.5hp Briggs motor model #120402-0213-E1 and I'm having a problem with the engine running at high enough RPMs to avoid dieing when I put it under load. The motor starts fine, 1st or 2nd pull with the choke on. I can move the choke control lever back to run and it runs smooth, no surging. I move the throttle control all the way to fast and the motor does speed up but not to where it should be. I have to over ride the governor to increase the RPMs in order to operate the tiller. The motor runs fine when I do over ride the governor.
Am I looking at a carb needing a good cleaning or something more involved?
Thanks for your help!
Mike
Old 05-28-14, 12:20 AM
cheese's Avatar
Received 138 Upvotes on 127 Posts
Sounds like the governor static tension spring needs more tension.
