Craftsman Diode in PTO Harness
Old 06-02-14, 04:51 PM
I have a Craftsman DYT4000 mower 917-273642. It was blowing the 20 amp fuse when I turned on the PTO. I have traced the problem to the diode in the PTO harness on the engine side. The diode melted and broke in half and burned off the insulation on the red wire from the PTO switch and caused a dead short. I need to replace the diode. What kind of diode do I need and where can I get one. Is there anything else I could do to fix this.
Old 06-02-14, 07:32 PM
cheese's Avatar
Received 138 Upvotes on 127 Posts
You can pick one up at radio shack. I don't know what part number it is. Take your old one if it still has legible info on it, or get one that is slightly bigger than yours and chances are it will be able to handle the current yours was made to handle.
Old 06-02-14, 08:09 PM
Received 3,892 Upvotes on 3,489 Posts
A good replacement diode would be a 6A05. It's rated for 6 amps at 50vdc. It's only there to suppress the excessive voltage you get when you open/turn off a coil.
6A, 50V Rectifier Diodes (4-Pack) : Diodes | RadioShack.com
Depending on where you are in the state you could also hit Wayne Electronics in Wayne and Greenbrook Electronics in Greenbrook.
