Pioneer P41 chainsaw
Need help trying to remove the flywheel off this saw it will not budge, used puller pry and hammer method it will not pop.
Leary of using impact gun on the puller or air chisel on crankshaft.
Any suggestions?
Thank You
Any suggestions?
Thank You
Try putting the puller on it with good tension and tapping on the puller bolt and a bit on the sides of the flywheel to shock it loose.
