pressure washer hose replacement
I have a 10-yr HomeDepot "Homelite" pressure washer and when I went to use it this spring the hose got a leak. I have tried to remove so that I can find and buy a replacement, but have had no luck...Do I have demount the unit in order to remove the hose???
Welcome to the forums!
I don't know about your particular PWer but most either have quick disconnects or are just screwed on. If the pressure line has never been removed it's likely rusty - PB Blaster and wrench or channel locks should help.
