Best way to get cutting blades off white outdoor 22 horse riding Lawn mower.....
Best way to get cutting blades off white outdoor 22 horse riding Lawn mower 50inch cut?
They are really hard to take off for me. not sure which way the bolt turns I think they come off in the direction of the spin ??any tips??- I will reply thank you
Get a long handle wrench with the correct socket size (hex vs 12 point if possible). Get some heavy duty gloves and a 2x4. The bolt or nut should be standard right-hand thread. You need to wedge the 2x4 in such a way as to prevent the blade from turning. Use some Liquid wrench to soak the bolt. You might need to put a cheater bar on that wrench handle. It would help if had someone else to help hold the mower or blade while you apply torque to the bolt or nut.
PS...Disconnect the spark plug before doing any work.
I hope that all of this discussion about the blades is predicated upon the deck being OFF the machine first. That makes it so much easier to inspect, remove, and re-install the blades.
