Power Washer No Pressure
Received 0 Votes
Hello,
I have a pressure washer with no pressure, After reading many comments and forums, I purchased a new unloader valve with no success, I has just purchased and installed a new pump, and still no luck?
Everything appears to be functioning properly until I squeeze the handle, I get a very short burst of pressure and the normal water pressure??
Any suggestions and help would be greatly appreciated. My wife suggested I just buy a new washer, but NO, I assured her I could fix this one. Help me out here and help all mankind
Thank you!
Craig
Thank you!
Craig
So now your pump is new but still no pressure? Then either the supply is poor or the new pump is bad. The short burst of pressure makes me think the pump is good and the supply is poor or you have the wrong tip on the wand (soap tip).
I use the quick disconnects and never have had any issues with them.
Before I start my PWer I always 'prime' the pump by pulling the trigger and making sure I have a good stream of water [no air] first.
Received 0 Votes
Well, I want to thank you all for your advice. I decided to purchase a new hose and spray handle, and it is working great! I sure can't explain why that fixed the problem, but it did. My wife is very pleased that I fixed it especially since I have now invested more than $300.00 in and old power washer. All I can say is? Actually there is not much I can say except, I'm sure glad it works, I can't imagine the hell I would have experienced if I had spent the $300 and it didn't work!!!!!!!!!!
Thanks again for all your advice!
