Toro PP Model 20055 Drive problem
Old 06-18-14, 06:46 PM
I have a 2007 Toro personal pace mower that is having issues with the left wheel/drive. It makes a clicking sound when you push it with the mower off and it also makes the noise while running. The wheel also has a lot of play in it. I can move it in and out a bit. I read on another thread that it could just be the clutch washer and maybe the bearings. Both wheels spin freely when they are engaged off of the ground. The left one does have issues when you put some pressure on it. It still mows but it does at times pull to the one side. Hoping to fix it before it gets any worse. Thanks in advance for any help and or ideas.
Old 06-18-14, 10:16 PM
cheese's Avatar
All I can suggest is that you take the wheel off and see what is causing the problem, whether it's a bearing or something broken or worn out wheel.
Old 06-19-14, 08:30 AM
I think I found the problem. I have a broken C clip on the inner assembly. I have ordered some from Toro and I will report back if that fixed the problem. Thanks
Trackbacks are On
Pingbacks are On
Refbacks are On
