Montgomery Ward Tiller w/ Briggs & Stratton engine
I have a Wards Tiller w/ Briggs & Stratton engine, the Model number is almost worn off It appears to be 15801 488337 but this does not produce any information when I search, I need parts breakdown specifically the carburetor any advice would be appreciated
Hello Teppler,
Look on the engine flywheel cover on the top down from the spark plug, You should find the engine model-type-code stamped there. With that you can find parts/info for the engine.
Good Luck
Good Luck
