2007 Troy-Bilt pony
Old 06-21-14, 09:19 PM
W
2007 Troy-Bilt pony
Hello I own a 2007 Troy Bilt Pony. I am having trouble with the mower not moving in reverse or forward. It is a 17.5 hp Briggs and Stratton engine( if this info is needed). When I put it in gear and let out the clutch, the drive belt begins to smoke, acts like transmission is locked up but it is not. Any suggestions?
-Thanks in advance!
Old 06-21-14, 10:09 PM
cheese's Avatar
Received 134 Upvotes on 123 Posts
Check the brake, it may be stuck. Does it roll fine?
Old 06-22-14, 08:32 AM
W
Yes it rolls fine when in neutral, and the brake is not stuck
Old 06-22-14, 08:14 PM
cheese's Avatar
I would suspect bad bearings in the variator.
Old 06-22-14, 09:07 PM
W
I will check tomorrow if they are bad or not . Thank you very much for your help.
