Riding lawnmower
Old 06-22-14, 07:20 AM
B
Riding lawnmower
I have a 90's model Murray 42inch cutting deck and a 15.5 hp BS motor. It has been working great until recently. I've noticed the past few times using it that it was jerking a little but now it only moves forward in the low gears. If I try any faster speeds my lawnmower just sits there. But if I move the gear shifter back to the 1 or 2 position it begins to move again at a slow speed. Also when I turn a tight corner in the slower speeds it starts jerking a little.
Old 06-22-14, 09:24 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums! Aside from transmission problems, have you checked the idler pulley on the drive belt? May have too much slack, or a worn/stretched belt.
Old 06-22-14, 01:40 PM
B
Ok thanks I will check that next.
