Briggs and Startton backfires wont start
Old 06-27-14, 05:05 PM
1
16HP OHC Craftsman riding mower - Was mowing when engine stopped running as if I had turned it off. Found an exhaust rod broken. Replaced rod, replaced the fly wheel key since I already had it apart. Cleaned the gas tank, fuel line, carburetor and air filter also. When I start it tries to run but backfires and will not run correctly. I had replaced the spark plug, no help so put the old one back in just as a test. Took the OHC apart and cleaned the valves. Still have the same problem with back firing. Remember that this is a riding mower so no bent shaft. Any suggestions?
Old 06-28-14, 11:06 AM
P
Received 2,120 Upvotes on 1,898 Posts
Did you determine what caused the rod to break? It could just be a symptom of the real problem.
Old 06-29-14, 07:06 AM
T
Received 31 Upvotes on 25 Posts
Adjust the valves, leave the exhaust on the loose side of the spec. That should stop the backfire and get you running again.
