Craftsman 42inch Lawn Tractor Doesn't Shift When Brake Depressed
Old 06-28-14, 05:07 PM
I have a Craftsman lawn tractor, 20 HP, 42 inch deck, 6 speed transaxle, model no. 917.272910. I just replaced the motion drive belt (v-belt, ground drive, part no. 130801) today with a new one because the old one was stretched out and kept coming off in the middle of mowing. I have the new belt on and now I cannot shift to any gear while the engine is running and the brake is depressed. When the engine is not running I can move through the whole spectrum of gears with no problem. When it is running and in gear moving over the lawn, I can shift from gear to gear with out depressing the brake. Only when the brake is depressed with the engine running I cannot shift from gear to gear. I tried adjusting the brake in both directions but that didn't fix the problem. Any advice on what might be the problem? Thanks!
Old 06-28-14, 11:41 PM
cheese's Avatar
Received 148 Upvotes on 136 Posts
Sounds like you bought a belt that wasn't OEM and it's too short.
Old 06-30-14, 12:35 PM
Thanks for the info. You are exactly right. I've put the original belt back on and it is shifting through the gears like it is designed to do. Now to find the OEM belt. Appreciate your reply.
MTCSSRetired
