Pull cord - hard to pull
Old 06-29-14, 09:22 AM
Hi everyone,
20'' Craftsman chainsaw, 46cc/2-cycle, model # 358.250201
The pull cord is not completely stuck but it is hard to pull in a single motion. It does go very smoothly when I take the plug out though. But when I put it back in... same problem.
I looked at the piston by taking out the muffler and it looks nice and smooth so I don't think the engine is seized. Besides, it slides well when the spark plug isn't there.
Tried some gas with extra oil in the plug hole and did not seem to help.
With some effort I can get the chainsaw started and it works just fine, but it is a pain in the neck to pull that cord.
Any guesses, suggestions, other things I should look at?
Thanks!
Floren
Old 06-29-14, 09:02 PM
cheese's Avatar
Did you check to be sure the chain brake isn't activated?
Old 06-30-14, 05:19 AM
The brake is not activated, once I get the chainsaw starts, it works fine.
Thanks for the reply though.
Old 06-30-14, 08:55 AM
You may have some carbon deposits in the head driving up the compression. Try spraying a good amount of carb cleaner down the plug hole. Then let it sit for a couple of hours, start it and run it for ten or fifteen minutes.
Old 06-30-14, 11:48 AM
Thanks for the tip Marbobj. I'll get some carb cleaner.
