Briggs and Stratton 5 hp mower choking out
Old 07-01-14, 10:39 AM
T
Having an ongoing problem with this mower. THE mower is not that old(maybe 5 yrs). Ever since my Son in law decided to test his mechanical ability and clean and reoil the oil filter, the thing hasn't run right.
I've done new filter
clean tank and carb atleast 3 times
new plug
it still continues to choke out and when it runs it just putt,putt,putt and the plug is black.
Hate to buy a new mover as I'm sure it's something simple, I just can't figure it out.
Any thoughts?
Old 07-01-14, 01:27 PM
G
Received 28 Upvotes on 27 Posts
First check to see that the oil is not over full, second try running it without the air filter to see if it runs any better. Have a good one. Geo
Old 07-01-14, 01:41 PM
T
Already did that. oil is spot on. Filter on or off, makes no difference
Old 07-01-14, 04:23 PM
G
Post the engine model, type, trim and code usually found stamped in the metal shroud just above the spark plug, it appears usually as xxxxxx-xxxx-xx. Have a good one. Geo
Old 07-01-14, 04:30 PM
G
I was thinking just as I hit the post button, does this engine have the carb setting on top of the fuel tank with the red primer bulb, if so you need a new diaphragm kit, about $5.
You need to install a new diaphram kit, it is Briggs part # 795083 or old # 495770 also Lowe's has a kit #5083 which has the same parts.
Here we go:
Remove air cleaner, there are 2 bolts that hold things together, one on the front of the tank 3/8" and one into the block 1/2", remove these bolts, now "slowly" slide the carb/tank off the intake tube and breather tube, now tilt the tank in to release the throttle linkage and waalaa the carb/tank is removed. Check the intake tube to see if the “O” ring seal and plastic retainer are still on the intake tube, if so remove them and re-install them into the carb. Remove the 5 screws from the carb/tank remove carb(don't loose the spring) now spray all holes, cracks and crevases in both the carb and tank surface with brake parts cleaner, remove the main screen(looks like a thimble), now with a small screwdriver pry out the main jet(carefully) and clean it, check the “O” ring on the main jet for damage, if it is damaged it must be replaced, reinstall the jet, it can be difficult some times to get it to snap back in place(I use the rounded end of a screwdriver handle). Remove and clean the fuel pickup stem(not necessary if the fuel tank was clean). Clean any junk/rust from the tank. Install the diaphram on the tank then the gasket(no goo or sealer) now carefully replace the carb(the spring will try to misalign the diaphram), tighten all screws a little at a time so as not to crimp the diaphram until they are all tight. Install the carb/tank in reverse order and you are done. If I missed something one of the real mechanics will correct me. Have a good one. Geo
