Tri-Fuel Conversion: Hose and Regulator Size
I just ordered a tri-fuel kit for my Generac 7550EXL generator. What I need to know is what diameter hose do I need (planning on 10'), and how many btu's per hour do I need to supply to the unit so I can get the regulator and hose awhile.
Kit that I looked at had the regulators included. Also showed 3/4" dia. hose for your setup.
Briggs Generac GN410 Propane Generator Tri Fuel Conversion Kit Gas Generators | eBay
You need to know the HP of the motor. I have not had time to look up what you have , but I think its 10k btu per HP...
For reference 1/2 inch @ 10 ft with a .622 ID will supply 175k btu...
Hmm says its 14hp.... thats 140k but... Wow what are you using that to power? 13,000 watts..
Your going to eat a lot of fuel.
I ran all of sandy 9 days on my modified 4050 watt gen. 12 gallons of fuel used...
( Modified meaning I rewired it for 120volt only as I have no 240 loads. I get full amps now at 120volts... No more trying to balance the loads/windings)
It is a 15 HP OHVI engine with pressure lube and electric start. 7.55KW running, 13.5KW surge. I plan on using propane and gasoline.
Yup, Mike. That's what it looked like when I got it.
That a pretty optimistic surge rating for a 7.5K generator.
Don't forget on propane you won't get your full rating.
I plan on using a 10' flexible rubber hose. Right now I have a 40# but I'd like to get some 100# universal fill tanks. I plan on using this for power tools, lights, PA system, crock pots, 6kw deep fryer, etc. (Not all at the same time of course)
I use this on jobsites, cookouts, outings, and the like. It's something I got for both work and play.
If a gen has a 7550k rating and a 13k surge, then that is a good head unit.... The problem is a 15hp motor is a gas gussler...
Are you doing any 240v loads? If not you better off moding you 4k gen for 120v only. Youll get full 30 amps... Use less gas...etc...
Going about it wrong IMO... I know you spent money on the conversion and all..
Mike, I usually don't have any always 240V loads other than the fryer and some 1500W quartz lights. Everything else has either a switch, or is auto-sensing. (I run my speakers and amplifiers on 240V when I can) However, one awesome feature of the 4000 EXL is it has both a 15A 120/240V receptacle on a 15A 2-pole breaker, and a 30A 120V receptacle on a 30A breaker, which can be used simultaneously. Add in the idle control feature, and you have a unit that's great on fuel. I'd like to tri-fuel that one later down the road, or get an inverter unit. But for now I'm going to get the 7550 taken care of, that's what gets the most use this time of year.
#21
I would recommend nothing less than a 160,000 BTU/hr. regulator. As long as the low pressure hose is no more than 10 feet long and does NOT have quick connects the 3/8 inch ID should be okay. If you want to go longer than 10 feet then you will need to upsize to at least 1/2 inch.
This company has all the parts you need. Low Pressure Propane Regulators, Twin Stage Regulators, Dual Stage Regulators
Whether or not you will experience a lower maximum output on the generator will depend upon several factors. My Yamaha EF3000ise has full output (3,000 watts) on natural gas although it is not a tri-fuel arrangement but gaseous fuels only.
#23
Well I got the regulator installed on the generator, then it decided it wanted to thunderstorm. Tomorrow is the 4th, Saturday I have a party to DJ, then Sunday I'm white water rafting, so who knows when I'll get back to it.
#26
Well I got the conversion done today, except I didn't get a hose yet so I'm still using gasoline until I get a hose. Here's some pictures:
The only issue here is the choke lever is too short. Any ideas on extending it?
My new starting system. The blue light is on when the key is on. The bulb is removable. I also added the 12V socket so I can use a phone charger without starting the generator. If the battery goes dead it can still be pull started if I pull the right connector on the engine block.
This reading was with a little under an 80% load.
#29
Quick question, would there be anything wrong with mounting the dual stage regulator on the generator, and feeding high pressure propane right to the dual stage regulator? That way I can use a much smaller hose.
#32
I'll definitely want to see some load figures on the completed set up. Those auxiliary venturis are often the cause of lesser output on gaseous fuels since they limit the amount of air through the carburetor.
#33
I got everything running on propane. The only down side is I couldn't find a short flexible hose rated for 160K btu's, so I have the 2-stage regulator hanging off the zero pressure regulator until I figure something else out.
This is the generator running at 110% load. I'd say it's doing pretty well. The only issue was the generator head was too hot to hold my hand on, which I'd say is a bad thing. Since I have no intentions to run that much load other than for testing I'd say everything seems good.
#34
May want to turn the governor up so unloaded your at 62 hz. This way loaded it should not bring you below 58hz...
But then again your not running sensitive things right?
As a plumber your going to wipe those joints right??
#35
#38
A rag...LOL.. Is that all teflon paste or some type of pipe dope?
Whats wrong with the regulator being there?
#39
The two-stage regulator needs to go somewhere else, though.
#40
Run a short hose and mount it down on the frame somewhere. I would rather have it on the gen somewhere. Like down by the wheel kit on the cross member...
