craftsman lawn mower vapor lock?
Old 07-03-14, 11:17 AM
N
I have a Craftsman 22" self propelled lawn mower. With a Briggs & Stratton motor I believe.
Starts right up when cold or even sitting all winter.
One or 2 pulls and it starts right up.
Never dies out cold or hot.
When I do shut it off when hot and want to restart it 15-30 minutes later etc it is a PITA to get started again. it will take 50 pulls or a heart attack (whichever comes first) to get it started.
I assume a vapor lock but not sure how to correct it or what I need to check first?
Thanks
Old 07-03-14, 12:30 PM
P
Received 2,101 Upvotes on 1,881 Posts
Can you post what engine you have (model number) so we can tell what carburetor you have?
Have you tried different starting methods when it's hot? Have you tried hot starting with the throttle partially or all the way open? Some engines need priming or choking when cold but that will prevent them from starting when hot.
Old 07-03-14, 01:14 PM
N
Not sure if this is what your looking for but in the owners manual it says:
Engine, Briggs & Stratton,
Model Number
122T05-0846-EA
Sears part number for the carburetor is 498170
The lawnmower model # is 917.376660
Old 07-14-14, 04:38 PM
bump
If anyone has any suggestions that would be great.
Old 07-15-14, 12:23 AM
cheese's Avatar
Received 138 Upvotes on 127 Posts
There are several threads recently about this problem. Poor design, the only reasonable workaround so far is to tilt the mower carb side up to let a little gas enter the intake, then it wills tart right up.
Old 07-15-14, 10:04 AM
G
Received 28 Upvotes on 27 Posts
I noticed on the sears site the original 498170 carb number has been substituted with a 799868 so maybe they found the problem. Have a good one. Geo
