Tillitson HU won't prime
Old 07-03-14, 03:02 PM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Hi All ,HU style diaphragm carb on my Trorbilt tiller won't prime,gas will go only about 1/2 way up the gas line, carb has been all cleaned.
Any thoughts.
Geo
Old 07-04-14, 06:04 AM
P
Received 2,108 Upvotes on 1,887 Posts
You said you cleaned it but did not mention replacing anything like the diagragm. Did you replace the diaphragm? Here is a .pdf service manual for that carburetor.
Old 07-04-14, 01:25 PM
Geochurchi's Avatar
I did not replace anything ,is the diaphragm sold separately ? Also I wanted to remove the throttle shaft because it seems that the spring may be broken but I can't find an Allan or Torx head that small,any idea what that wrench might be?
Geo
