Mitsubishi MGE6700 runs no power
Old 07-04-14, 01:36 PM
D
I have a Mitsubishi MGE6700 generator from 1999 with probably 2 hours on it. Motor runs great and starts on the first pull after cleaning the carburetor but it makes no power. I tried exciting the field with a drill in the AC outlet and with a 12 volt battery across the brushes. I'm fine identifying the parts and using a multimeter and am generally somewhat handy but am out of my league diagnosing generator problems. Any help is greatly appreciated. I have a wiring diagram that I can send but the file is too large to attach at 173KB.
Old 07-04-14, 05:32 PM
Received 3,884 Upvotes on 3,481 Posts
Welcome to the forums.
I have the schematic here also.
You'll need to check all the windings with them disconnected. You have approx seven windings there that you need to check first. You don't need to check the DC charge winding.
Have you also checked the brushes ?
