Small Engine Problem
Old 07-06-14, 10:33 AM
A
Hello Everyone,
My name is Seth. New to the site. Decided to join after reading how to repair my Riding Lawnmower which I appreciated the the clear answers I found on this site. So here is my question.
A couple of years ago I build for my Son a small motorcycle. I took a small electric motorcycle and added a 22cc scooter/ 2 stroke engine. I don't really know anything specific regarding brand about the engine as I pieced this together as I came across parts. It has disc brakes for front/ back with single lever (cable) that works each caliper simultaneously. Gas is operated by thumb control from a small 4-wheeler.
The rig ran great for a couple of season then last year it began to give me trouble. It wdid not want to idle no matter how much adjustment I attempted. When the scooter runs it does OK if you just let it idle/ very light pressure to throttle and it will move along slowly but as soon as you add throttle it begins to die. If I jack it up and keep the back wheel off the ground I can get it nearly to full throttle then it just dies. No amount of "feathering" of the throttle will keep it going. I have taken the car apart and cleaned it. I changed the gas and made sure I was working with a fresh tank. I am stumped as to what is going on and why I can't get it back to full operation. This little machine would run like a demon....It has 10 inch tires (top to bottom) and with me would hit 35mph (maybe faster if I would have had more road). My son really want this thing running again and so Do I but I have spent countless hours trying to fix the problem and cannot. I would appreciate any help or ideas very much.
Thanks for the help
Seth
Old 07-06-14, 07:04 PM
cheese's Avatar
Received 146 Upvotes on 135 Posts
How much compression does it have? Might check to be sure the exhaust isn't clogged. If both check out, I would suspect carburetor problems.
Old 07-07-14, 11:14 AM
P
Received 2,185 Upvotes on 1,955 Posts
I would first look at the exhaust like Cheese mentioned. Long ago I had a small 2 stroke engine that would plug the spark arrestor screens in the exhaust. It became part of my maintenance and I'd clean it out once a season.
Old 07-07-14, 01:11 PM
Received 840 Upvotes on 737 Posts
I'd also install a new sparkplug. I had a 2 stroke bike 40+ yrs ago that didn't like old plugs, even if you cleaned them well.
Old 07-07-14, 07:34 PM
A
Thanks
Thanks for the ideas. I never tried the plug as it wasn't that old/ many hours on it as it was sparking fine. But maybe that will play a role. Will definitely try the exhaust repair as it gets very heavy with oil in the discharge. May very well likely be restricted.
Thanks fellas
Seth
